Hello,
This code below works. I will filter by drop down and the results will show in the text fields, for text field 2,4, and 6. But when I try adding "text8". That data set it is assigned to will not filter and will just stay blank. The other 3 text fields will filter and display with no problem. I seem to run into trouble when I add that 4th data set and 4th text field to be filtered.
The text in green is what I added, but wont filter and display results. Other 3 work fine (Red, Blue, Yellow), not sure what the problem is.
import wixData from 'wix-data'; $w.onReady(function () { }); export function button1_click(event, $w) { let generalFilter = wixData.filter() .eq("size", $w('#dropdown1').value) .contains("weight", $w('#dropdown2').value) .contains("height", $w('#dropdown3').value) let RedFilter = generalFilter.eq("color", "Red"); let BlueFilter = generalFilter.eq("color", "Blue"); let YellowFilter = generalFilter.eq("color", "Yellow"); let OrangeFilter = generalFilter.eq("service", "Orange"); // This line was added but wont filter like the others Promise.all( [$w('#dataset1').setFilter(RedFilter)] [$w('#dataset2').setFilter(BlueFilter)] [$w('#dataset3').setFilter(YellowFilter)] [$w('#dataset4').setFilter(OrangeFilter)] // This line was added but wont filter like the others ) .then(() =>{ $w('#text2').expand(); $w('#text4').expand(); $w('#text6').expand(); $w('#text8').expand(); // This line was added but wont filter like the others }) }
Thank you for your help!
