I'd like to create a custom horizontal menu with submenus because the 'normal' WiX horizontal menu does not give me all the design options I'd like to have.
For testing, I first created a button that should later act as a main menu button. In addition, I created a container respectively a vector art that should become the submenu (it is hidden on load). The vector art is snapped to the button so that there is no space between the two elements. A screenshot of my elements is shown below, labelled with the corresponding Ids.
What I want now is that #submenuitem appears when my mouse enters (onmouseover) the area of #mainmenuitem. When the mouse leaves (onmouseout) #mainmenuitem the submenu #submenuitem should disappear, but only if the mouse does not enter the area of #submenuitem. If the mouse moves from #mainmenuitem to #submenuitem the submenu should still be shown, so that the user is able to select items of the submenu.
The basic functionality already works (i.e. mouse entering and leaving #mainmenuitem area and then showing / hiding #submenuitem.
However, when I start adding functionality for #submenuitem, the application does not behave how I want it to behave. When I enter the area of #submenuitem it seems that it is still disappearing every second time (see video below).
Below I listed the Corvid code I used so far:
var inmainmenu= false;
var insubmenu= false;
var subshown = false;
export function mainmenuitem_mouseIn(event) {
inmainmenu = true;
toggle_submenu()
export function mainmenuitem_mouseOut(event) {
inmainmenu = false;
toggle_submenu()
export function submenuitem_mouseIn(event) {
insubmenu = true;
toggle_submenu()
export function unternehmensub_mouseOut(event) {
insubmenu = false;
toggle_submenu()
function toggle_submenu(){
if(inmainmenu){
$w('#submenuitem').show();
subshown = true;
if(!inmainmenu){
if(insubmenu){
subshown = true;
else{
$w('#submenuitem').hide();
subshown = false;
Maybe anyone has a suggestion what I am doing wrong here? I would appreciate any hint! 😊
