Trying to import contacts from a CSV file, but WIX doesn't recognize a csv file sent out from gmail, or a csv file sent out from a database. All CSV files are grayed out when attempting to import to contacts. Any suggestions?
To see this working, head to your live site.
Hi i had the same probleme a few month ago you should try to delete the empty lines and column in your CSV in order to only have a board that contains boxes filled with text
Hi Marcus, no luck. I tried getting rid of empty columns - didn't work. Then I pared the csv down to one column of information and it was still grayed out. :-(
Hi @llilli5163, this is a general Wix.com question, I suggest you'll ask our support in support@wix.com because this community is about Wix Forum product.
Sorry about that. But just in case anyone else needs to know, I switched from using Firefox to Chrome and that fixed the problem!
