Hi, I made an event via the Wix Events app. On Desktop version it looks great but on mobile, an extra button appears. I've attached some screenshots below. Does anyone else have this problem? Any ideas how to solve it?
I'm a product designer for WIX Events. Thanks for the feedback!. We will look into this problem, but meanwhile what you could do is to disable the "RSVP Button". To do that you need to go on the desktop version of event details pages. Then you would need to click on "Settings" to open settings modal where you need to click on "Display". At the bottom you should see "General" section. There you need to disable "RSVP Button". In this case you should not see double buttons on mobile version. The downside of this, that you are disabling the button on desktop too.
Hello Kenny,
I hope I could help.
