I have instructed my installer to go to a certain url and download a prerequisite. The link I supply is for the 32bit version of CrystalReports. For some reason it always gets the 64bit version. I have double checked the link and it is correct. If I paste the link in a browser it goes to the correct destination and downloads the correct file. Automating it through my installer gets the wrong file.
<PackageGroup Id="CrystalReports32"> <ExePackage Id="CrystalReports32" DisplayName="Installing CrystalReports32" Cache="no" Compressed="no" PerMachine="yes" Permanent="yes" Vital="yes" DownloadUrl="
http://downloads.i-theses.com/?task=download_file&fileid=1014&no_html=1" InstallCommand="/passive /norestart" Name="Installers\CRRuntime_32bit_13_0_22.msi"> <RemotePayload Description="CR32" ProductName="CRRuntime_32bit_13_0_22.msi" Size="95000" Version="13.0.22.0" Hash="1B818CC23357B6857BE85D715A54673E8315914B" /> --><!--<RemotePayload Description="CR32" ProductName="CRRuntime_32bit_13_0_22.msi" Size="95000" Version="13.0.22.0" Hash="1B818CC23357B6857BE85D715A54673E8315914B" /> Name="Installers\CRRuntime_32bit_13_0_22.msi" DisplayName="Crystal Reports 32 bit" InstallCommand="/passive /norestart /l*vx log.txt" InstallCommand="/s" Protocol="none" SourceFile="Installers\CRRuntime_32bit_13_0_22.msi"--><!-- </ExePackage> </PackageGroup>
Hello @howard taylor, I suggest you to post this issue on the corvid forum: https://www.wix.com/corvid/forum They will help you more informatively as this is a forum for the Wix Forum product only.
@Mantas Peldžius @howard taylor You will find that the Corvid Forum is of no help either. Wix only provides support for CORVID, not HTML code from external sources.
@Mantas Peldžius
He doesn't mean Wix as in Wix for website etc, he is thinking that this is the Wix Forum for Wix Toolset - https://wixtoolset.org/
He should be looking here instead on the correct website - https://wixtoolset.org/documentation/
Happens many times on the Corvid Forum too 😉
hi i want to make a copy of this website http://golddetectors.pk/ and https://buydetectors.pk/ with wix platform can someone help me with this
