Hi, my editor doesn't launch anymore. It gets stucked on the loading page.
My other wix websites are working.
I tried everything on the support page : try a anonymous mode new window, update web browser, try an other web browser, get the Betternet Unlimited Free VPN Proxy plugin for Chrome, restart browser and computer ...
Can somebody help me ? Thanks
Weird that you haven't got any feedback yet. Are you sure the thing is about VPN? Actually, free web versions are pretty useless. I'd try at least Nord VPN version (based on the source) to make sure everything is alright with the connection to servers.
I had this issue before. Wix Editor is pretty laggy. I notice you are using a mac so forgive my ignorance but I notice when i have this issue its because i have alot of tabs open other browsers. I normally use mozilla on my windows 10 for internet browsing and I use Edge for wix editor cause it works much better there. I would suggest a reboot and less open tabs and if possible run a clean up on your computer using CCleaner and or clean your cache.. Not saying this will be the solution but its what works for me when Wix Editor is misbehaving
Hi, @djoly72, this is a forum about Forum app only. The general support team will assist you more effective. If you're still having an issue please contact support@wix.com
