Two or three days ago forum recent feed add-on froze on the option "Date posted". It doesn't matter, if the other option is chosen, for instance "Last activity". When you go to "save and publish", it comes back to "Date posted".
Getting complaints from my users.
Thank you.
Thank you for informing us! Will be fixed as soon as possible.
My 'recent posts' add-on only seems to be showing posts from our 'Admin' member 'Mark'. Even mine as Owner are not showing. You will see on my Home Page that only Mark's posts are showing although other members have posted in between his posts. I have also created posts after Mark's.
www.hdmds.co.uk
Issue is now resolved. Please check and let us now. You may need to remove and add the widget back to fully refresh it.
Yes, it works, thank you. No removing and adding back needed.
Great!
My site is still the same. How do I remove the widget
Did you checked "Last activity" in settings? Try to do that before removing and adding back the widget.
All working now, many thanks
