Something Isn’t Working…
It looks like there was a technical problem. Here’s what you can do:
Refresh the page.
Check your internet connection.
Open the site in a different browser.
First time I've seen this in 7 months on a site build I've been working on. This happens the night I I have members finally logging in. ummm. just a hiccup?
It appears to have been remedied 🎉.🎈
After fresh reinstall, going directly into the forum settings. Live comments work
After clicking on Theme Manage button (only) in editor. Comments are are disabled, forum is crashing.
No editing was done to the settings. The "after" screenshot shows that my theme manager presets auto-filled back in.
I've discovered that it seems to have something to do with a conflict with the theme manager. In testing, by doing a fresh install of the forum app, the forum works fine live, but, when I go to Design>Text Styles, I discover that all of the text styles are all blank. When I click on a drop down I have the options to change font and size only. I do not have an option to change any theme manager text options (header1, paragraph3, etc). Settings>Design>Icons and Buttons has colors listed that are not in my theme manager. At this point, the forum on the live site works fine. I have the ability to write a comment
In the editor, when I click on "Theme Manager" or do anything to the page that uses the theme manager, like turn the background of the page to a color, which uses a color from my theme manager, I discover that when I go back to the forum settings, both Design>Text Styles and Design>Icons and Buttons have updated with my preset theme manager settings. When this happens, the forum on the live site goes back to erroring with the "no comments" issue.
I am having same issue.
Hello, Sorry to hear that you're having these troubles. Usually it's very temporary, are you still getting these issues?
the "write a comment" section isn't showing up in the "start a discussion" nor in the responding to a post. When you click on the area, it should be at, or cancel out "discard message", I currently get that error.
