How could we use a custom product version format for Wix Product/@Version - Eg 2022.02.01? If i do it using a compile time variable (@), it gives me the error - Product version must have a major version less than 256, a minor version less than 256, and a build version less than 65536 If i try using binder variables like file version, then it cannot have the format I need since I only need a 3-part format. Also it will not allow 02, since it makes it 2. I've gone through some links like the below, which don't seem to help a lot with the scenario I have. https://stackoverflow.com/a/641094 https://stackoverflow.com/a/8555951/8052403accessories Any suggestions/ideas/guidance? The Wix version we use is 3.10.2.2516. However I feel the behavior is irrespective of the version. I see some entries in the Windows Features list (highlighted in snapshot below) which seem to have values greater than 256 in major/minor versions. "How did you do that?"
