Hello! I am trying to put together a simple art portfolio site for my daughter. I have four tabs, Paintings, Drawings, Photography, 3D, each of which is a main page with a bunch of thumbnails. When you click on a thumbnail, it takes you to a subpage with a full size image of that drawing. I cannot figure out how to move from one full size image to the next without having to return to the main page with thumbnails:((. I am using the Graphic Illustrator template from the Portfolios collection, and in that template, there are actually Previous and Next arrows on those subpages. But on each subpage, each arrow is an actual link to the next or previous page. That means that if I change the order of images in the thumbnail gallery, that Next arrow's link is going to take the viewer to a wrong (old) image. There has to be a more advanced way than manually rewriting all those links! Is there? Thank you
You are better suited asking on the Corvid Forum.
Also, this tutorial should help.
Thank you! I actually saw this tutorial, but I don't think it applies to my problem. My subpage is not dynamic, it's just an image, a scan of my daughter's painting. I do not think it has a dataset, and it does not generate content. And I wouldn't know where exactly to insert all of that code in the HTML content:(. I believe there is an arrow somewhere in the Wix tools with the function of flipping to the Next/Previous page, but so far I could not find it. I will try asking on the Corvid Forum. The Wix support person named Jane told me yesterday that if I just put the arrow there, it will automatically start working, with the right links. And of course, I can copy/paste the arrow from the template, but, unsurprisingly! it doesn't do it's thing... And she doesn't answer my emails any more.
