Good day, everyone! Basically, what I would like to know the convenient way to import our data from Airtable to our Wix website. If you're not familiar about Airtable, it's like excel but it's much more user-friendly when it comes to storing data such as list of information and etc., and we use that software to organize our data and the information we gathered there. Just like excel, you can place your pictures here and there. Now, we have this certain set of data, let's call it "spreadsheet" we need to import it to our Wix website, and we tried to export the .csv file and import it to our Wix website using the content manager but there are issues like on our first import, there were no pictures included and on our second import, the picture's file names are indicated but the pictures cannot be found. We tried that with different computers and its the same results. We also tried Corvid with the adapters and the like, but we found out that it's much more complicated to do so, because it requires coding such as CSS and Javascript to be able to translate the data from Airtable API to Wix API. We don't have knowledge through complex coding and we wouldn't want to spend too much time on it, time short and we need to import it right away. The problem here is we want to import the pictures as well but we weren't able to do so if ever you guys have suggestions or options, please let us know. thank you!
Yes jecject.you can store in a folder and from there you can insert you picture and add in you Wix website
Will try that, thank you. Although we want to put the image automatically on the image box in the webpage. Because it only shows the file name than the pictures themselves, is it possible?
Alright jecject.I would be glad and happy that you find solution to your request.it have been a pleasure to help you out today
Thank you Ramayade :) will let you know if I succeed.
Hi he next.you could transfer the data in a file and download it and then you sent to Wix and from the website you can add you picture.what I mean is that in Wix website you look for picture to add to your document
So I have to do it manually, like one by one than importing it all together?
Yeah I think it could work
Is there an option where we can import the data and the images all together?
Did you wanted more help jecject
After putting your document in the file download it and sent in Google drive and from there insert the picture and you put your final edit in Wix.Is that procedure more helpful
I'll try that in a bit, I'll ask someone from the Airtable side. if I can download all of the images, they're like 500+ and i have to put them on each data
You are welcome
To export data from your database collection:
Click Content Manager on the left of your Editor.
Click the collection you want to access. Note: Your Editor's default collections are Sandbox. ...
Click the Show more icon and select Export to CSV.
Choose one of the following options: ...
Click Export.
