Hey @Ohno
So there are a few areas where you can do this. The first one is in the editor (double click on the forum in the editor to bring up settings). Go to Categories -> Edit Category -> Description. If you delete what's written in this field, it will remove the description.
Or you can do it from the published site. Firstly press on three dots when you are inside a specific category (or the cogwheel):
Go into edit category (or manage categories):
In a chosen category, just delete what's written in the description field:
Be sure to save the changes if you are doing it in the published site. If you are doing it in the editor, don't forget to publish it after the changes! 🤗
If you want to turn off headers for categories completely, go into editor -> settings (double click on the forum) -> layout -> select posts page -> and turn off the toggle for header:
@Ohno Seems to work on my end (this is the homepage in categories):
This is a general discussion category I've deleted the description in:
Be sure that main page has separate controls for the header than the categories that are split in the editor:
If this does not help, maybe you can send me a screen-recording how are you trying to achieve it or your site URL so I could check if it's an issue specifically to the site? Feel free to message me at: mantaspe@wix.com
Hey @Ohno So there are a few areas where you can do this. The first one is in the editor (double click on the forum in the editor to bring up settings). Go to Categories -> Edit Category -> Description. If you delete what's written in this field, it will remove the description.
Be sure to save the changes if you are doing it in the published site. If you are doing it in the editor, don't forget to publish it after the changes! 🤗 If you want to turn off headers for categories completely, go into editor -> settings (double click on the forum) -> layout -> select posts page -> and turn off the toggle for header:
Thanks but it didn't help, cos your methods also remove the description parts from my home page.
Thanks friend.
I really appriciate your effort in trying to help me.
