I get no error message or any notification. It will just not react. I've tried different devices, different accounts but when I attempt to post it will not publish? I've tried copying all content and pasting as plain text to remove formatting, I've tried to remove links and photos. Nothing works. Has anyone seen this issues? Is there a solution?
Mar 23, 2020
I can publish some forum posts, but some do nothing when I click publish?
Hi, are you still experiencing the issue?
Yes
The issue now seems fixed on my end, THANK YOU! I can't tell you how refreshing it is to see a dev team that actively listens and works to respond to real time issues.
@Cam Papermaker, we're pleased to hear that :) Trying to react as fast as we can.
I am experiencing this issue, too, @Greta Galubauskaitė.
It seems the more time one spends in writing a post or a reply, the greater the chance that ”Publish” will not work — like a page time-out or something. If it helps in identifying the problem at all, there is also an issue that, if the page is open in a tab for longer than 5 minutes, none of the links work on the page — also like the page timing out. It happens here in this forum as well.
Hi, I will forward your feedback to devs. The one with 'expiring' links is interesting - let us investigate. Thank you, Robin.
@Greta Galubauskaitė Please help me too.When I try to send post on my phone I have the same issue.Publish button does not work.I dunno how to solve this error
Is the problem persistent? Please share the link to your forum, @onuryeral601
@Greta Galubauskaitė, I'm also experiencing this! I've only been able to publish a post once, and it was just the word "test." I can't edit the post, and I can't post anything new - nor can anyone else, on any browser. One person can't even get past the login screen -- the buttons simply don't work. What is happening?!
