Hello,
I'm sorry if I'm not in the correct forum category to discuss about this. I already contacted the wix support, few weeks ago, but I do not have a relevant answer about this issue.
Each time, I click in the "3 dots" forum option menu (everywhere in the forum), the menu is displayed with a transparent background.
The same thing happens with the new "Create new post" button, which is impossible to read :
I know exactly where is the problem : I'm using a transparent post background (0%).
So, if I modify the post transparency to 100% in the forum app, the "3 dots" background menus and "Create new post" are not transparent.
My problem is : I want to keep a post transparent background (0%) ... because the "Manage Categories" background (the right panel with all options to manage my categories) is using the correct color and is not transparent.
Why the forum menus transparency is linked to the post transparency ? And not linked to the "Manage Categories" options background ?
The menus are displayed on top (above) of all posts or categories ... so, it they are transparent we can't see the menu options easily.
Thank you very much for your answer.
Yep, it is an annoying computer virus/feature. There ought to be an choice to set different backgrounds for each of website features like on Beginners embroidery machine segment.
Hi, I am sorry to hear that happened to you. The issue is known and will be solved soon.
Yep, it's an annoying bug/feature. There should be an option to set different backgrounds for each section. #featurerequest
