Notification bell and details on the side of the account indicate that there are unread notifications, actual notification slide reads otherwise. I have refreshed and still the issue stands. Please fix.
ah ok ! no problems, if you can communicate on this with us, its better than leaving us without knowing , so thanks for that...just i hope that's soon, cya cya
S'il vous plait réparez au plus vite les notifications car j'ai des remontées négatives de nos membres maintenant, cela touche donc notre développement qui en prends les frais.... Help ! Merci pour votre travail !
Mine isnt working either. The number of notifications didnt clear. I had over 500 notifications but had visited. That issue is now resolved, but once i click on notifications it says there is no notifications here, even though there are many new posts on the forum.
i take this opportunity to add again my proposal https://www.wix-forum-community.com/forum/wish-list/add-a-button-to-remove-the-gif-of-notifications its really important, I never show that elsewhere, a forum without this option, you can say "ok, if you check it elsewhere , you can go elsewhere, ..." BUZZZZZZZZZZZZZZZ not really, i paid this service 20 € per months, and i have an obvjectiv to add an e-shop.
Hi, Sam, the issue is known and we've been working on it.
We fixed it!
hi! when ??? have the same prob now since two days,
Sorry for the inconvenience. This should be resolved soon!
Thanks! :)
I have this issue too, and today I couldnt post on my Blog either!
the problem is in the url, theres a thing of code after like that " %3FpostId%3D5d046ed26f84dc03e3ec597c%26origin%3Dnotification "
exemple =
https://www.docteurpeinture.com/forum/materiels-materiaux/recherche-de-marque-de-menuiserie-posee-il-y-a-15-ans-ou-equivalent%3FpostId%3D5d046ed26f84dc03e3ec597c%26origin%3Dnotification
Me too with Notification problems.
théoriquement cela fonctionne à nouveau , chez moi en tout les cas, pas toi ?
Hi, I will reach out to you and check your case!
Hi, your request makes sense. This is added to our wish list which has its own priorities. Let's stay tuned!
Hi, Robert, thank you! This is still the relevant request, in deed. Let me share this to the team and check how this will fit in the plans.
Hi, was this issue ever resolved? I also seem to be unable to clear read notifications.
Yes, we're addressing this issue. How many unread notifications do you have?
@Domas Sabockis 161. I've removed the notification bar for the time being so as not to annoy my users.
