So the support experts just use the same answer every time I ask this question - "Wix does not support 3rd party code snippets. Please go to the developer of the code to fix the issue."
The frustrating problem is there is NO issue with the code snippet. Tested it on jsfiddle.net, WordPress and Duda...all work just fine.
My client likes WIX because they can make edits easily. But WIX will not allow the code to work on the site. Has anyone dealt with this? Any workarounds?
Here is the snippet (for a marketing automation form): <script id="dcn4GjQC" src="https://prime-tech-pr.kizen.com/form/dcn4GjQC.js"></script>
I got the code working, you can see it live here.
<!DOCTYPE html>
<html>
<body>
</script>
</body>
</html>
Obviously this code is meant to be put in a HTML Iframe.
Basically the reason you're experiencing the problem is because Wix HTML Iframes are sandboxed, meaning that they have to match a specific format to work properly.
https://grandcraps.co.uk/keno-games/ here you can relax and have fun!
