( If it's not possible to change the text on the member login button I thought a way to go around it would be to create a link to the login page myself, but I do not know the url for the login page, since it is not showing. )
@Heath H-M Thanks alot. I will look in to it. Is it also possible to change the text on the login page? As it is now, it is a poorly translated English sentence to Swedish. Want the text in Swedish, but it does not look very professional with a gramatically incorrect sentence. Would also like to keep the header of the web page while logging in, if possible.
@Karl-Johan Fabó The link I sent you was for custom login/signup lightboxes. That means you can have your own branding, translate it properly, etc, etc.
Depending on which type of lightbox you choose, you could also just have it open in a pop-up, side panel, etc.
Best solution. Custom Login/Signup Lightboxes. [UPDATED]
@Heath H-M Though, it seems that the URL is not working
@Karl-Johan Fabó Sorry. I've corrected the link.
@Heath H-M That would be just perfect. I will have a look at it as fast as I have some spare time. Thanks!
