Hi forum friends, I have a website that has two menus. The main menu is on a public facing site and then the second menu is unfortunately made up of buttons in the members site as you can only have one menu per site with wix. I have a problem in how to create the button menu on the members site so it is mobile friendly. Is there simple yet effective way to create this second menu so it is also mobile friendly. Any advice would be most gratefully appreciated. Many thanks Russell
Solved my own problem. Themed icons hidden on the PC/ Laptop platform but then unhidden on the mobile view, works a treat👍🏻
Eu não falo o inglês. I' do no speak inglês. Thanks!
Ok!
