Hmmm, well while 12.8 mbps is not SLOW, it’s also not that FAST either. For example, my internet speed is 500 mbps. Nonetheless, 12 mbps is not slow enough to give TOO MUCH of a noticeable difference for your issue. However, how much ram do you have and what type of processor are you using?
Also, to slightly increase your internet speed and reliability without having to upgrade your speed, try connecting your computer to your router using a 1 foot cat 8 Ethernet cable. They’re very cheap and you can get them on amazon.
Then it sounds like an issue on wix’s end. However, this is not the forum for your needs. This forum is only for the forum app. Try opening up a ticket with wix support.
This sounds like your internet and computer needs upgraded.
No it's not a problem of computer or internet connection ...
On my Wix account, I have two website, the publisher on one works very well and on the other it does not work very well.
Another administrator of the website also has the same problems while working on a different computer.
Go to fast.com and see what your internet speed is. It’s fast and free and very accurate and it’s powered by Netflix.
My speed is 12.8 Mbps
It does not come from the internet connection ...
Hmmm, well while 12.8 mbps is not SLOW, it’s also not that FAST either. For example, my internet speed is 500 mbps. Nonetheless, 12 mbps is not slow enough to give TOO MUCH of a noticeable difference for your issue. However, how much ram do you have and what type of processor are you using? Also, to slightly increase your internet speed and reliability without having to upgrade your speed, try connecting your computer to your router using a 1 foot cat 8 Ethernet cable. They’re very cheap and you can get them on amazon.
I think you do not understand well, it is absolutely not a problem of connection or PC ...
I have two accounts at Wix and on one of the two account the editor works very well
This forum is for issues/requests related to the Wix Forum. You are better suited asking Wix Support about your issue.
Does it take long to process?
Abdul
Keighley Removals
