Hello, Wix team. something just started occurring today and I wanted to make sure you knew about it.
Normal behavior: Go to a category, select “Create New Post”, write post, click “Publish” at the bottom. Expected: the post is published into the Category one was in when they selected “Create New Post”
BUG behavior: Go to a category, select “Create New Post”, write post, click ... oh wait, there is no longer the option to “Publish” at the bottom. It now says “Next”. As if someone changed the forum to something less workable, it now makes you select which category to post in — even though you were already in the Category you wanted to post in.
What?
I don’t uderstand this.
Why make the forum less usable?
Is there a thought process that I am missing. (I am happy to be apprised of it — it’s not like I think I’m right all the time — I just want to understand this new forum bug).
This should not be like this. We'll investigate what's happening. Can you share the forum URL this is happening in?
@Domas Sabockis — it is a private forum, so I’ll have to send you the link via the chat here.
Same to my forum
Investigating.
Screen shot the area you are having issue and send it to me I will told you what to do
Hello Wix Team —- just and update that this bug is still happening in my forum. Thanks for escalating it ... :o)
@Domas Sabockis
@Greta Galubauskaitė
Fix will be out for this shortly.
Thank you for the update, @Vytenis Butkevičius.
Thank you, @Vytenis Butkevičius and Wix team ... this bug seems to be gone now.
Did you try to use the extra features in your website? I have used the Wix seo plugin too rank my website. Check here how I implement the plugin.
