please what template you would recomend to create a web presentation with several lines of surfboard shapes and some pages with tech etc...
I'm affraid this kind of web would be hard to sqeeze into some one page for all type of presentation, that I like, but its probably too much.
I would also like to run a blog as a part of the web.
all this is just my personal hobby presentation, I'm not really making any money by shaping some boards for friends, so its suppose to be simple, easy and cheap.
thanx for any help.
Im an artist trying to attract googles attension. If you want to write on my new forum and have me visit your site every so often we might help each other. https://www.artjanetdavies.com/forum Please leave a link.
this forum seems to be not really helpfull. wix is suppose to be easy and I just spent 4 days trying to figure out if i'm gonna be able to build my web here or not as I need sub-sub pages not supported here,
I just found a possibility to create the button linking to hidden page, that enables kinda make submenu....
now the problem is that when I try to link a button, the menu for editing a link is showing so much to the upside of the screen, that I cant see the top part of the menu. fullscreen doesnt help either. as I cant click on the top of the menu I cant move it down either. what to do ?
You can add as many pages as you want. I find that if I click and hold the cursor over the menu, I can drag it down. Perhaps that is what you have tried to do. You don't have to use a template, I just drag images to where I want then, get the page positioned so that the space you want to add the image to is showing on screen, then you don't have to drag it as far, make it smaller by hovering on a corner and pushing it in wards. The add text. Don't know if this makes sence to you or is any help. I struggled with forum but have got it set up now, just no visitors despite inviting folks, so not sure if it is working or not. Let me know if you get yours set up and we can visit each others.
Hi, this is Wix Forum Community, for your general questions about Wix @john doe please contact our support center here.
