Jul 24, 2020
The Zoom out and Reorder button is missing from toolbar. Wix can't help. Anyone have a solution? Have cleared cache already.
Hi Stephen What device are you using with zoom?.you need to used it on your computer
Using on computer for past year. Yesterday the Zoom Reorder button disappeared
It is really weird .just go to the setting and see how you could add the record button if possible
I'm having the same trouble
I don't see the button either. I just started using Wix about 2 weeks ago. I didn't even know there was supposed to be a Zoom Out & Reorder button until I started reading about it in Help. I was trying to understand how to work with page sections, and I'm not sure I'll be able to do it, without this button. Sure hope Wix fixes this.
