Hi Raf
According to my test that I did yesterday and today, the android typing issue is not yet fully solved. There is a cursor issue still remaining. When I try to edit a word somewhere in the text and then try to continue write my text, the focus of the cursor is going back to the editor word....Need to try 2-3 times to get the focus back... ...
It's better than it was , it's faster than before, but it is still buggy on Android, and I question some of the design and layout decisions on desktop (which doesn't display content prominently) and mobile (post list is too large)
recap:
The editor doesn't work on Android
It's
^ slow
Words get cut
^ off
To be frank, it's
^ terrible .
Hi Paul, we fixed the android issues - which issues you seeing now? Which features you’re waiting for?
Hi Raf According to my test that I did yesterday and today, the android typing issue is not yet fully solved. There is a cursor issue still remaining. When I try to edit a word somewhere in the text and then try to continue write my text, the focus of the cursor is going back to the editor word....Need to try 2-3 times to get the focus back... ...
Wix blog might be fixed, Wix forum is not, just look at the problems with my posts
In fact, the editir is a nigthmnigh
That should say nightmar
Mobile layout too large
Prefer how categories work in Wix
^ blog .
Want to apporove new posts from new members to stop
We will check - mobile experience should be similar to blog one - btw did you check it on our mobile app? http://wix.to/ScBjAEc
Paul, are you sure that when you're writing the same thing on blog there are no issues and they appear only here?
Not sure what you mean. I tested the blog editor the other day, it seems fixed.
This editor is still
@Paul Phillips I mean writing a comment on a blog post via a mobile website. Same issues appear as well or not?
^ buggy .
@Domas Sabockis editing still doesn't work on Android. If you try respositioning the cursor it fails
Ok, this scares me. I just established this site to use as a forum. Should I embed a 3rd party forum before I launch? Thanks
Try classic layout, or the newly released compact :)
I don't want the same layout on desktop and mobile though.
@Paul Phillips the compact layout on mobile without pictures no nice
