Hi,
I'm looking for a way to modify wix-store cart page only (so i keep using the others pages of the store).
I need to add nearest shipping relay points based on an external API and the customer's address.
I could do that in 10 minutes using Javascript, but you cannot get the element ID of the shipping method selection input... so it's impossible to do.
Is there a way to contact the support team directly to ask them to give me FTP access to the website, so i can modify it like i want to ?
Or
Is there a mean to modify their cart page without having to remake a new complete store with Velo ?
If i have to use time learning Velo, it would just be better to move the website on a server where i'll be able to do what i want with the code... so i guest Wix should probably have options to modify the code of a website ?
Thank you in advance for your answers.
Hi! We would love to help, however this is a Forum for Wix Forum app matters.(https://www.wix.com/create/forum). I have, however, created a ticket for our Customer Care department on your behalf. You will receive a reply to the email you used to sign up in the community. In addition, you can search for answer in Wix eCommerce Community: https://community.wix.com/ecommerce
